USB Rotary Table?
USB Rotary Table?
Does anyone know of a rotary table manufacturer that is USB capable and can give position data?
I am trying to prototype a test system but I need the PC that will be running the system to command the tables position and receive information about where it is as well.
Any ideas or known companies?
Thanks!
Thanks!
RE: USB Rotary Table?
TTFN
See:
http://www.excitron.com/webdocs/getstarted.cfm
under 8 inches in diameter
no more than 6 inches in height
a holding force of 25lbs
360 degrees of freedom
15 degrees per second or more of travel
resolution of 0.1 degree with he same repeatability
Ill check that link too Clyde. Thanks IR!
