Temporary Road over Dirt Surface
I heard there is a kind of material (liquid), which can be poured over dirt, and then firms up to become a temporary road. I am looking for this kind of material, which is both low in cost and can support truck weights of approximately 15 - 25 tons.
I would appreciate if anyone knows the name of this type of material and who is the manufacturer of it?
RE: Temporary Road over Dirt Surface
http://www.enviroseal.com/products.htm
TTFN
Could you provide more detail about "snake oil", where I can find more info and manufacture about it?
Thanks again
Lin
seems pretty real, but obviously, you'll need to investigate as required.
TTFN
Thanks very much for the information, that really helps!
Lin
Is there any like "tape" material can be used?
What's the difference between them (pros and cons).
Thanks!
There are three common methods of striping...
1-conventional paint, using a traffic resistant paint (least expensive method)
2-thermoplastic paint, a thermoplastic "paint" that is melted and sprayed onto the surface (usually used for highways)
3-thermoplastic/thermosetting tape and pre-formed features that are put into place then heated to bond to surface.
Ron
If it sounds too good to be true, it probably is.
