Measure transient voltage drop
Can anyone recommend a (simple to use) power quality analyser or multimeter that can record the voltage drop on a power system during motor starting? I want to hire an instrument and measure voltage drop on the 220V single phase supply (on a ship) when a 3ph motor starts (the motor is higher up the distribution system).
The simple to use bit is the crucial bit as I want the ship's electrician to be able to use it and so it needs to be fairly easy for him to drive. I don't want a test instrument that needs 3 days of reading the manual before you find the button to turn it on!
RE: Measure transient voltage drop
I can't find the exact model right now, and it's probably obsolete anyway. It was a multimeter with datalogging and graphing capability, and only a little harder to use than an ordinary multimeter.
Mike Halloran
Pembroke Pines, FL, USA
the first time to joint for this forum
Best Regard
Ryan
