Plywood-to-plywood wood screw lateral capacity
I have a 20"x20"x1" thick plywood panel that is connected to a 3/4" plywood skirt. (6)-6 GA screws are connecting the two pieces of assembly (screw tip is 1/2 into the 3/4" thick skirt. What is the screw design value for single shear connection, and what is the plywood-to-plywood shear capacity (is there a table in the NDS showing the plywood crushing capacity?). See attachment for description of the connection.
thank you in advance for the responses.
RE: Plywood-to-plywood wood screw lateral capacity
Garth Dreger PE
AZ Phoenix area
