Water Flow vs Temp Difference........
We have a water/glycol brazed plate heat exchanger. In general terms, should we expect the delta T to increase with increased flow or decrease?
Water Flow vs Temp Difference........Water Flow vs Temp Difference........(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Water Flow vs Temp Difference........
Tata
Q = htc*area*deltaT. If Q is constant and htc increases, then deltaT decreases, doesn't it?
TTFN
If you increase the flow on the water side, the heat transfer cofficient on that side will increase, of course, increasing the overall heat transfer coefficient. This will increase the delta T on the other side. However, I don't think it will increase the overall heat transfer coefficient enough to result in a higher delta T on the water side.
As IRStuff pointed out, the water side delta T is inversely proportional to the flow rate if the Q is constant. It's a pretty good bet that the effect of the water flow is greater than the effect of the increased heat load.
Speco
Thank you all very much for your input!!
Q = M*cp*ΔT
with cp = water specific heat capacity
Tata
The fact is, we sometime get a little sloppy in our terminology. Delta T can mean three different things in a heat exchanger.
1. The hot fluit change in temperature. Usually T1-T2
2. The cold fluid change in temperature. Usually t2-t1
3. The effective temperature temperature difference between the fluids, or Log Mean Temperature Differenct (LMTD)
In IRStuff's posting, he meant LMTD
In Ione's posting, he meant the temperature change in either fluid.
I believe the original poster was referring to one of the fluid temperature changes.
Speco
I will endeavour to be more precise with my future postings as it is quite clear that a thread can come unravelled if not properly mended. One could say "a stitch in time saves 9". No more punny references, I promise!!
thank you all again!!
CamLoch
In the limiting (absurd) case, an infinite coolant flow would result in a zero deltaT across the inlet and outlet, since you would now have an infinite heat sink.
TTFN
Let's not forget that no matter how much we improve one individual heat transfer coefficient, the overalll heat transfer coefficient would stay at a value smaller than the lowest of both individual values.
