Simplify Assy Grayed out
I'm still stuck on V19 - I tried to create a simplified assembly to then try and save as a part and export as dumb solid.
However, the 'simplify' toolbar is grayed out.
I'm pretty sure I've used it before, I thought at V19, any idea what's up?
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Simplify Assy Grayed out
Hi, you need to first activate the simplify environment, then the toolbar will become active.
I have not used V19 for a long while but I think from memory you do this under the application drop down menu.
Hope that helps.
Jon Sutcliffe / Solid Mastermind
The Solid Edge Community. Video training sessions, best practice documents, process maps and interactive training http://www.SolidMastermind.com
