Need Help Understanding Thermal Cycling
I am using Ansys to model a simple 2" beam welded to a 48" x 24" inch plate(Check Image). The beam is skip welded with 2" welds every 6". The inner surface of the beam is heated continuously to 900 degrees F while the air on the plate is cooled by air down to around 250 degrees F. It reaches a steady state condition. The material is 304L stainless steel with around 1/4" welds. The plate is fixed on all 4 edges. The thickness of the stainless steel is 0.06"
I have seen over 100 units in the field over 3 years that have not failed under 100s of cycles. My Ansys model shows stresses in the hundreds of thousands of psi. Could anyone give me some insight into what is happening? The Ansys model shows a failure but none of the real world units have failed.
RE: Need Help Understanding Thermal Cycling
if you are looking to predict ther life at the welds you need to look at a specific weld fatigue code (BS7608)
regards
Priam
www.priamengineering.co.uk
Tata
