Chilled water system economy cycle thro' cooling towers
I have an application that has a large chilled water demand even in the middle of winter. It goes down to -5 deg C outside here regularly in winter and the outdoor temp is below 5 deg C for 15% of the year...
Can I use the cooling towers to provide cooling directly to the chilled waetr system via a heat exchanger...
Does 5degC outside mean I can get the cooling tower down to 5 degC?
Has anybody try this before, any literature on it anywhere on the web on how you would pie it and control it.
RE: Chilled water system economy cycle thro' cooling towers
Sure,  there are a number of ways of doing it.  Sump heaters in the tower to prevent freezing when there is no flow. Insulated and heat traced condenser piping.  Then pipe to a plate heat exchanger.
I was just reviewing an existing installation that used a Trane chiller with economizer mode for free cooling.  The chiller uses convection of the refrigerant to cool the chilled water.
There should be details of a water-side economizer in the ASHRAE Handbooks.
Tower Tech towers have some descriptions  of this application as well.
