what is second linear object for chamfer dimension-NX5?
I have a chamfer that I am trying to dimension and when I click on the line the prompt asks for a second linear object for chamfer dimension. I try clicking on other lines but am unable. What do I need to do to get this second linear object to click on?
RE: what is second linear object for chamfer dimension-NX5?
If the chamfer feature is used on the model then you won't be asked for that second linear object when that chamfer is dimensioned on the drawing.
Instead of including chamfers in the sketch I usually use the chamfer feature. The same goes true for blends on a model - it is best to use the blend feature.
I hope that works.
I created a triangle, extruded it, gave chamfer to one of the edge (edge parallel to extruded direction), found that I can't give Chamfer dimension!! :(((
First, please state what type of Chamfer feature you're using. There are a few different types of Chamfer features, aren't there (Single Offset, Offset/Angle, Freeform)
Also, there are different settings for the Chamfer dimension...one way will just display the offset value without an angle and another way will display both the offset and the angle values...and there might be yet another display option available. What options are you using?
The reason I ask is because of that angled surface....if you're using an Offset/Angle Chamfer feature, then the angle needs to be calculated WITH the draft of the "vertical" angled surface in mind or else you'll overshoot the chamfer angle. For example, if that is a 5° angle on the lower "vertical" surface, and you apply a Chamfer with an offset of 20 and an angle of 45°, then the measurement for the angle will end up being 50° when measured from a straight vertical line rather than the 45° that you input for that value. The correct input for the surface to result in 45° from vertical is actually 40° due to that 5° angle being included.
Took me a few years to catch onto that. Once I did, I quit using the Chamfer feature and just controlled it in Sketches. Maybe not the way I'm "supposed" to do it, but I found it much more reliable than the feature (for what I needed at the time).
Try using the Chamfer dimension WITHOUT a Chamfer feature (include it in your Sketch)....you might be surprised....and I reserve the right for a disclaimer if it doesn't work out right either! ;)
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
