Bearing regreasing procedure for motor
Dear All
Please suggest me about the procedure for the bearing regreasing, should it be done while a motor run or stop? (Due to I found that grease let through the bearing into winding and many motors fail because of this problem)
Thank you
PAP
Thank you
PAP
RE: Bearing regreasing procedure for motor
http://www.machinerylubrication.com/article_detail.asp?articleid=339&relatedbookgroup=Lubrication
for more info
http://www.reliance.com/prodserv/motgen/h7000ch1.htm#Greasing%20Ball%20and%20Roller%20Bearings
In the ideal world, you would follow the recommendations of the motor manufacturer, since there are subtle differences in bearing seals, and the cavities/housing in which the bearing sits, and the flowpaths from fill to bearing to drain.
In the real world most people find a method they are comfortable with and stick with it.
Some of the important parts of the procedure:
remove the fill and drain plugs and clean fittings.
inject the proper quantity (see lots of charts for lub quantity based on bearing size, speed, duty).
Run the motor for 1-2 hours with drain plug removed to allow excess grease to drain.
Replace plug.
1. Type of bearing
2. Type of lubricant
3. Type of motor
