Drafts from imported models
Hey
I imported a .stl file into ST2 and saved it as .par but if I try and create a draft the views are all blank.
Is it possible to make a draft from a imported file?
RE: Drafts from imported models
I've uploaded the part that I was trying to make the draft from.
Is there possibly another format I could try?
The model was made in 3D max. Is there another format that I could try to export the model as?
Thanks for the suggestions bmlkidd.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
My advice would be to use an alternative export (as has already been suggested) from 3DS Max. It supports Iges so I would try that.
Jon Sutcliffe / Solid Mastermind
The Solid Edge Community. Video training sessions, best practice documents, process maps and interactive training http://www.SolidMastermind.com
