function composed from another functions - "solve" does not work
I have a function composed from another 3 functions and I like to obtain points where f(x) = 0. So in attached I expect 4 values, but solve does not work. Please help.
RE: function composed from another functions - "solve" does not work
GregLocock, did you open the attached ? On my computer when try to "solve" MYY(x) MYY is in red and note sais "This variable is undefined"...or do you see on your computer a result ?
Quote:
On my computer when try to "solve" MYY(x) MYY is in red and note says "This variable is undefined"...or do you see on your computer a result ?
That's not what it says on mine: "polycoeff" is not defined, ergo MY(x) is not defined, ergo MYY(x) is not defined.
Occupant, maybe better to post a printscreen in this case, I guess that you have set default value for array origin to zero, I have array origin set to one. And hope you can see clearly, that MYY(x) is plotted so it have to be defined
I would use the minerr function.
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
Oops, or the root function.
Peter Nachtwey
The setting of ORIGIN goes with the worksheet, why would I have changed it? "polycoeff" is not a Mathcad function and not defined in the worksheet you submitted, therefore, it creates an error. The obvious conclusion is, you uploaded only a portion of your worksheet. How can you expect to get help with an error that you yourself created by submitting this?
skjoex,
It maybe that mathCAD's symbolic solve command cannot solve for x when MYY(x) is a function with embedded if/then logic.  Either way, pretty impressive worksheet.
Oh..and polycoeff *is* a MathCAD function in my version (v14).  Maybe Occupant's conclusion isn't so obvious. ;)
Steve
Stephen Seymour, PE
Seymour Engineering & Consulting Group
www.seymourecg.com
I have to admit, I am not using v14 but v13 and I had to go back to find out. If you're right, how come "polycoeff" turned red (in V14-M020 and V13, of course) and I got "this variable is undefined". If it was a function recognized by Mathcad, I should have gotten "this function does not apply here" or some such thing.
It's actually part of the Data Analysis Extension Pack, which should have come with Mathcad 14.:
polycoeff(vx, vy) Takes two real vectors of the same length vx and vy and returns the coefficients of the interpolating polynomial function
TTFN
