Slug Flow in steam/condensate return line
I have a 265 psig steam/condensate line return from a heat exchanger back to a flash steam drum. It is about 5 wt% vapor/95 wt% liquid, and 80 vol% vapor/20 vol% liquid. Liquid velocity is 3.5 ft/sec; steam velocity is 15 ft/sec.
We are experiencing slug flow as evidenced by regular oscillations in condensate flow/drum level/steam drum makeup valve opening, not to mention a visibly swaying pipe. The pipes were designed for 2-phase flow using the Baker Chart.
We are trying to remedy this problem now and I would like to ask for advice on the best way to mitigate the effects of slug flow. Placing a restriction orifice at our steam drum does not help reduce the amount of vapor due to our available pumping head and cooling requirements.
Will providing additional piping support do anything besides keep the pipe from failing catastrophically? Will we still have our oscillating flow?
Any help is greatly appreciated.
RE: Slug Flow in steam/condensate return line
