Retaining Wall with Log Loader
I have review duties for a bio-fuel project in GA. It has a ramp for Volvo log loaders to use (4 wheels, 50k each max load).
Ramp data:
Walls are 14" thick and extend 4' above travel surface to contain the loader(s).
Width: 35' (inside of walls)
Fill Height: 10'
Level Ramp Length: 35'
Sloping Ramp Length: 50'
Soil is Clean Structural Fill
The design engineer is using a 200 psf surcharge and has no barrier impact load included. What is the minimum design criteria that should be used (the AASHTO 250 psf seems low to me) and what about the barrier load from possible contact with a loader wheel?
Ramp data:
Fill Height: 10'
RE: Retaining Wall with Log Loader
