High occupancy handrail laods
Has anybody ever speced a higher handrail load in areas where it will be common for people to line up side by side and lean on the rail?
I suppose 200lb or 50plf is a tough load to achevie, but I have seen rails that supposed work for those loads and i would not want to have in the above mentioned condition.
RE: High occupancy handrail laods
Check with the European Soccer leagues...  I am sure they have developed a new standard after the "crashing" fans have caused a number of handrail failures....
