A little help grabbing the last cells
Hi guys.  I am not the best at writing code.  I typically just record simple macros.  However, I have a sheet that gets updated daily and I want to be able to take the last 7 rows (a weeks worth) of data and export into a separate table on another sheet.  Any help would be greatly appreciated.  Thanks.
RE: A little help grabbing the last cells
That's kind of essentially what I'm trying to do.  The thing that is making it tough is the fact that the raw data is getting updated every day and I'm just trying to get it to where it only pulls the last 7 days at any given time.  Something like, "Range("A65536").End(xlup).Select".  Can I do .End(xlup)-1, -2, -3 etc?
Alright, I think I'm getting close here.  I can't get my offset squared away.  I actually want to take the last 8 rows, with data, in the spreadsheet.  The dates go on for years.
    Selection.End(xlDown).Select
    ActiveCell.Offset(0, 1).Range("A1").Select
    Selection.End(xlUp).Select
 -->ActiveCell.Offset(-8, 0).Range("A1:L9").Select
    ActiveCell.Activate
    Selection.Copy
    Sheets("All").Select
    Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
        :=False, Transpose:=False
*note, the arrow I put in is to show the line of code that Excel is not liking.  It is not in my VB code.
I think you can achieve what you seek without resorting to any macros, by using a combination of:
»  A "dynamic range";
»  The INDEX function;
»  Entering this INDEX function as an array formula.
See the example that (I hope) I have uploaded.
http://files.engineering.com/getfile.aspx?folder=429c5656-4cdf-4955-8c22-d618fac3edec&file=ExtractionDemo.xls
Oh, if you look again at the file I posted, notice on the summary tab that the dates automatically update. The dates use the " =TODAY() " function so the summary sheet always lists the last 7 days.
-- MechEng2005
Thanks for all of the help.  I ended up getting it to do what I wanted by using the sumif() function.  I set it up to where the data automatically gets pulled depending on what the date is.  I'll continue to tweak it though and may try to incorporate what guys suggested in this sheet or others that I build.
