DIN 2533 Flanges?
DIN 2533 Flanges?
DIN 2533 Flanges?
I work using the Imperial System of units and now I need to adapt to pump with a metric flange. The details of the flange are given by DIN 2533, PN16/DN100. I know it is 100mm nominal size but now I would like to put a flange to bring everything back to imperial after the pump. Does anyone know where I can find details of this flange such as bolt circle, od, id, etc?
Thank you,
Gabriel
RE: DIN 2533 Flanges?
Does a PN16 and PN20 flange have the same dimensions?
The threaded DIN FLanges have an NPT Center?
din 2533 flanges are weldingneck flanges,
What are you talking about threaded?
greetings
What happens is my pump has a DIN 2533 flange and then I would like to bolt a DIN XXXX Flange with a threaded female center (NPT Ideally). Does that exist?
You are talking about a dn100 flange and you want to connect a threaded pipe, what size?
Is it the suction or discharge?
You are too vage to answer this question.
Please be more clear.
Greetings
It is for both the discharge and suction and yes I want to connect a pipe. The pipe size is 3" Male Pipe Thread (NPT) on the discharge and 4" Male pipe thread (NPT) on the suction. I just want to know if they make such flanges? I will just call a DN100, PN16, with threaded NPT female center if it exists.
I don't know a pipespec. that uses this and I shouldn't do it that way.
But if you still want to do it that way;
Take a blindflange, drill a hole in it, and weld a (half) coupling npt to it.
Greetings
