Brg Length for HSS
Brg Length for HSS
Brg Length for HSS
If you have a rectangular HSS bearing on an unstiffened angle seat connection, which limit state do you use to find the required bearing length for web crippling? K1-4 of 13th edition?
the seat will be slightly wider than the HSS width to allow for flare welds
TIA
