Plotting Style(s)
Plotting Style(s)
Plotting Style(s)
I can not get my plot styles to work?
im trying to plot drawings but for some reason the center lines ( standard style) are not showing as they are in model space, to the paper space or ploting.
ive set the plot options to 'plot line styles'
but this has no effect???
my layer is turned on yet when i plot i get a constant line instead of a center style intermittant dashed line.
anyone help?
thanks
chris
RE: Plotting Style(s)
Check your line type scale, type 'LTS' in command line and play around with it so to speak if its at 500 change it to 1 or if its at 1 change it to 100.  This will change all line types in your drawing.  Or select another line type to use there usually are a couple like dash dot(5x) dash dot (2x).
thanks.!
