Non-corrosive structural material to handle saltwater at depth.
Hi there,
I am working on a project that involves a spherical structure that will operate in salt/freshwater depths of 75 - 300ft at temperatures ranging from 34 to 65 degrees.
The structure itself will be subject to centrifugal force from current flow ranging between 8-18 knots internally, as well as external currents of 4-9 knots and pressure at depth.
I am hoping to be able to employ some kind of moldable composite, preferably with low friction properties.
intended use is permanent submersion.
Any thoughts on materials that could handle these stresses would be greatly appreciated.
RE: Non-corrosive structural material to handle saltwater at depth.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO, BP
"Being GREEN isn't easy" ..Kermit
http://www.youtube.com/watch?v=hpiIWMWWVco
http://vir
"Scientists dream about doing great things. Engineers do them." -James Michener
