Updating Objects in an assembly - Low performance
I use NX 6 and have one particular assembly which is driving me crazy! It has about 300 components in it so its not very large, certainly not as big as others I have worked on. If the master assembly is selected as the work part and then I make one of the components the work part, NX takes about 20-30 seconds to perform the task. It says "updating objects" whilst it makes the component the work part. If I then go back and make the master assembly the work part again(having made no changes at all) it takes another 20-30 seconds to switch back. It is the same if I try to move a component. The assembly has less than 10 assembly constraints and maybe 30 wave linked parts. I could understand it takes time to update things if i make a change to something but it has this delay with every mouse click! I've tried using Tools-> Update-> Delay Interpart but it doesn't seem to have any effect.
Please, for the sake of my sanity, can anyone help?
Munners
Munners
RE: Updating Objects in an assembly - Low performance
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Munners
