Wrapping Exhaust Pipes
thread71-162827: Insulation of Car Exhaust
Re: the above thread
Concensus seems to be that wrapping exhaust header pipes is a bad idea but that coatings may be beneficial. I saw no clear concensus on wrapping exhaust pipe downstream of header outlet except that corrosion may increase.
My question is: Is it possible that keeping the gas hot and the velocity high is beneficial because flow in the pipe is pulsating, not steady state, and that a column of gas flowing at higher velocity has more momentum and at the end of the pulse a rarifaction is created at the outlet of the header and the entrance to the exhaust pipe and that said rarifaction improves scavenging.
RE: Wrapping Exhaust Pipes
- speed of sound changes with temperature, and the smaller diameter pipe would make temperature lower not higher.
- would pressure drop (restriction) w/higher density flow in a smaller diameter pipe be the same as w/lower density flow in a larger diameter pipe at the same average velocity (and mass flow)? Offhand it seems like no, but I've not looked at the equations.
I was going to ignore this thread because I think the question is too general to answer in any definitive sense (like always, "it depends")... but I just had to pick a bone.
Shielding nearby components is a reasonable reason for adding insulation, but should be approached with caution. FWIW, I used to specify exhaust pipe/manifold insulation, for a machine that had a heat exchanger on the exhaust for cogeneration. Getting an insulation of any kind to work effectively for 1000 hrs. was a real chore, due to corrosion/erosion of the manifold caused by vibrating abrasive oxides next to hot metal. And, the fiber insulations do make lovely wicks for oil lamps, changing small oil leaks, spills and drips into lovely, bright flames.
Was that a bone or a nit or maybe even a nits bone.
OP
Pipe insulation certainly helps upstream of a turbo, however if to well insulated, the structural integrity can be reduced both short and long term by stress cracks from thermal cycling while bolted to more stable parts and from increased corrosion or oxidation at higher .
downstream or with no turbo, like Isaac says, it all depends. Protecting surrounding parts or keeping intake charge cooler might be valid reasons.
Changes to air speed and speed of sound and tuned length and scavenging effect and camshaft overlap and back pressure, ambient conditions, engine speed etc etc etc all are variables to be considered.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
However...I have insulated a couple of turbo installations that saw a distinct performance increase. These were for street applications and not race specific. The insulation typically lasted several years before needing touchup/replacement. Race specific applications have no such limitations. Race headers don't normally last more than a few seasons due to other problems...crash...demounting/mounting damage, etc.
Rod
