600 KVA Diesel Alternatives
Right now we use a 600 KVA Diesel Generator capable of putting out 1443 amps. The unit operates a single 350 HP motor, a single 75 HP motor, and several other smaller HP motors and axillary equipment. The biggest issue is the amp draw, and this force us into using a 600+ unit.
My problem is we are being forced to move away from the diesel generator towards a LPG generator. What are some good options? I haven't seen anything capable of putting out that amperage, will I need to get several units?
RE: 600 KVA Diesel Alternatives
CAT, Cummins, Wakausha, MAN to name a few.
