Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It's extraordinarily refreshing to see truly expert advice without having to wade through hipper than thou attitude..."
Geography
sklev (Structural)
24 May 10 16:46
I am trying to figure out my governing load cases for the roof (joists, etc.) of a warehouse I am designing and am getting hung up on the E factor. I just graduated and was never required to determine E in school (it was always a given). I am working my way through the code and am getting hung up on my QE factor. I am stuck here because all of the other factors that I am using in my basic load cases are in units of psf. If I use V or Fp as the code suggests to determine QE, my units  are inconsistent (lb vs. psf). How do I translate these factors so I can use them to determine my governing basic load case for roof design?
Helpful Member!  JAE (Structural)
24 May 10 16:51
E and Qe are "effects" in load combinations.  In other words, for a given set of basic loads applied to the structure, each load case (such as dead, live, seismic) create effects in structural elements.
Effects are things like moment, shear, axial tension, etc.
So you obviously don't mix psf with lbs.
You would calculate the applied force on each member (such as your joist) for each load case.  These in turn create various effects and you combine them per ASCE 7 in the given load combinations.
sklev (Structural)
24 May 10 17:49
Thank you. I think that my head is getting in the way and that I am over-complicating things.
sklev (Structural)
25 May 10 13:11
I had seen thread507-237438: Seismic Load Effects but still didn't quite understand. What does the A represent?
JAE (Structural)
25 May 10 14:30
Which "A" are you talking about?  I looked at the thread and didn't see it.
sklev (Structural)
25 May 10 15:59
Sorry, I copied the wrong link.
thread176-98527: ASCE 7-02 Seismic Load effects
(A(dead) + A(live)) + rho x A(seismic) + (0.2)(SDS) x A(dead)
JAE (Structural)
25 May 10 17:28
In that post I was using Axial (A) as an example of an effect.
Close Box
Join Eng-Tips® Today!
Join Us             Close
