Thread Engagement?
Thread Engagement?
I'm threading an aluminum tube with a M60x2 thread. I want to use a steel retaining nut but I'm wondering how much thread engagement I need to keep my 14,000 lb load from shearing the threads clean off on the aluminum tube. The typical 1-1.5 diameter rule or 5 threads doesn't seem to apply here. Any thoughts?
Thanks!
Thanks!
RE: Thread Engagement?
You might be able to validate your result on www.boltplanet.com
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Ted
Have a look at this site:-
h
desertfox
thread725-35222: Tensile capacity/minimum engagement
Chris
www.value-design-consulting.co.uk
