Can a P.E. sign off on Landscape Plans?
This L.A I know mentioned that a P.E can actually desgn and sign a set of Landscape Plans. Keep in mind this is Florida so the statutes may allow this.
RE: Can a P.E. sign off on Landscape Plans?
I am registered in Florida and it is my understanding that a P.E. cannot seal landscaping plans. It is a separate license, R.L.A.
Please post back if you hear otherwise from the Board.
LA and LC - A "registered landscape architect" means a person who holds a license to practice landscape architecture in this state. A Landscape Architect may perform the following services, including, but not limited to:
• consultation, investigation, research, planning, and design;
• preparation of drawings, specifications, contract documents and reports;
• construction supervision;
• landscape management, including the use of Xeriscape, to the extent that, the dominant purpose of such services or creative works is the preservation, conservation, enhancement, or determination of proper land uses, natural land features, ground cover and plantings, or naturalistic and aesthetic values;
• determine the grounds and approaches for and the siting of buildings and structures, outdoor areas, or other improvements;
• setting of grades;
• shaping and contouring of land and water forms;
• determination of drainage and provision for storm drainage and irrigation systems; and
• the design of such tangible objects (retaining walls, gazebos, fences, etc) and features (waterfalls, ponds, etc).
Unlike landscape architecture, landscape design is not a licensed profession that is regulated by the State of Florida.
http://
FAQ
http://ww
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
Here is the landscape architect act from Illinois:
(f) "Landscape Architectural Practice" means the offering or furnishing of professional services in connection with a landscape architecture project that do not require the seal of an architect, land surveyor, professional engineer, or structural engineer. Such services may include, but are not limited to, providing preliminary studies; developing design concepts; planning for the relationships of physical improvements and intended uses of the site; establishing form and aesthetic elements; analyzing and providing for life safety requirements; developing those construction details on the site which are exclusive of any building or structure; preparing and coordinating technical submissions; and conducting site observation of a landscape architecture project.
I like the part that says "offering or furnishing of professional services in connection with a landscape architecture project that do not require the seal"
The Florida Act seems to be a paradox. The landscape architect should not seal plans for items like retaining walls because he has no expertise in that area. The landscape architect should not put his seal on plans prepared by another engineer either.
An engineer can not put his seal on a landscape architect's work either because the LA work was not done under his direction. In addition, the LA work is probably not worthy of sealing anyway.
A P.E should not be stamping anything that is outside his/her field, for a number of obvious reasons regardless of similar discipline, simplicity, worth, etc.
In either case, it would not bode well for me. I'll stick to what I know.
Mike McCann
MMC Engineering
Motto: KISS
There's about 20 items there and I don't recall seeing one that a PE couldn't do, unless you're refering to "aesthetic".
I see reseeding, planting with all kinds of plants and many various reinstatement works on pipeline RoW details.
"Being GREEN isn't easy" ..Kermit
http://www.youtube.com/watch?v=hpiIWMWWVco
http://virtualpipeline.spaces.live.com/
I suspect that is what your RLA buddy means.
In the Florida law, the cross practice between Landscape Architects and Civil Engineers is less clear. The following provision in the statute seems to allow it:
(6) This part shall not be construed to affect part I of this chapter, chapter 471, or chapter 472, respectively, except that no such person shall use the designation or term "landscape architect," "landscape architectural," "landscape architecture," "L.A.," "landscape engineering," or any description tending to convey the impression that she or he is a landscape architect, unless she or he is registered as provided in this part.
Chapter 471 is the Engineering Law and Chapter 472 is the Surveying Law. The "Part I" reference is to the practice of Architecture.
BOTTOM LINE...as several noted, check with the state board!
