break alignment macro
Dear Experts:
Below is a recorded macro for jog/unjog of a dimension. I'd love to have a break alignment macro, but the macro won't record break alignment for some reason.  Is there an easy way to modify below to achieve this?  It's for swx 2006.
Const NOTIFY_ERRORS As Boolean = True
Dim swApp As SldWorks.SldWorks
Dim swDoc As SldWorks.ModelDoc2
Dim swSelMgr As SldWorks.SelectionMgr
Dim swDim As SldWorks.Dimension
Dim swDispDim As SldWorks.DisplayDimension
Sub JoggleToggle()
Set swApp = Application.SldWorks
Set swDoc = swApp.ActiveDoc
Set swSelMgr = swDoc.SelectionManager
If swSelMgr.GetSelectedObjectCount <> 1 Then
    If NOTIFY_ERRORS Then MsgBox "Select a single dimension and run again"
    Exit Sub
ElseIf swSelMgr.GetSelectedObjectType3(1, Empty) <> swSelDIMENSIONS Then
    If NOTIFY_ERRORS Then MsgBox "Select one dimension and run again"
    Exit Sub
End If
Set swDispDim = swSelMgr.GetSelectedObject6(1, Empty)
If swDispDim.GetType <> swOrdinateDimension Then
    If NOTIFY_ERRORS Then MsgBox "Dimension was not ordinate"
    Exit Sub
End If
If swDispDim.Jogged Then
    swDispDim.Jogged = False
Else
    swDispDim.Jogged = True
End If
swDoc.GraphicsRedraw2
End Sub
RE: break alignment macro
Don't know about SW2006, but the SW2010 API Help section shows...
Visual Basic (Declaration);
CODE
Sub BreakDimensionAlignment()
Visual Basic (Usage);
CODE
Dim instance As IModelDoc2
instance.BreakDimensionAlignment()
Here you go:
CODE
Sub IwannaBreakSomeDimensionAlignments()
  Application.SldWorks.ActiveDoc.BreakDimensionAlignment
End Sub
By the way, that's not a recorded macro you've got there.  I know, 'cuz I wrote it.  winky smile
-handleman, CSWP (The new, easy test)
Thanks guys.  Yep, I realized after I posted, going through the code, that it wasn't recorded.  I couldn't remember where I got it from, though, so I figured the owner would correct me.  =)  And you did!  So thanks again.  It's been very useful.
