Data overview window ANSYS 11
I'm having a problem with the Ansys 11 engineering data.
Yesterday i was using the simulation normally, creating new materials and setting their proprieties. Today when i opened the program and went to the "engineering data", the "data overview window" wasn't there. In every materials, be it created or loaded from the ansys library, the "data overview window" doesn't appear. I tried to reinstall the program but no result.
Does anyone knows who to fix it?
RE: Data overview window ANSYS 11
From the View in the menu select "Restore Original Window Layout" and I think things will be back to normal again.
If this does not help you might need to remove the Ansys folder in your profile folder (under "documents and settings" folder).
I hope these help!
Thanks Mertsi1340, but i've already tried to do that and had no success.
