Dust Mitigation
Dust Mitigation
I would like to limit dust buildup in a paper mill on horizontal and vertical surfaces to improve housekeeping. In humid areas of the mill fans tend to cause fine paper dust to stick to vertical surfaces and make buildup quite an issue. We are looking into air treatment to limit humidity but this will not completely solve the problem. I am investigating products that may be applied to surfaces to limit the roughness. The concept is to apply a coating that would allow the dust to "slip" by conduit, ducting, and concrete walls instead of sticking to them. Does anyone know of products available to do such a thing?
RE: Dust Mitigation
