Construction Joint in Elevated Composite Floor
Where is the best possible place to put a construction joint in a composite concrete and metal deck floor slab?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Construction Joint in Elevated Composite Floor
I would use the middle portion of the beam span - and away from any major girder line.
Joints parallel to the beams:
Midspan of the slab span.
If you are counting on Composite action between the steel floor beams and the concrete, then try one of the other suggestions above.
