Gen Set Improvements
I recently installed several compact 24.5kW (continuous rating) gen sets. Space and weight are very big considerations as well as reliability. These units are turbo charged diesel, vertical 4-cycle, 4 cylinder, 2.0L liquid cooled units. They seem to have substantial vibration which the maker says is normal. Fuel consumption is about 2 gallons per hour.
This is not my thing. The units work well but what are the possible set of improvements that I can go back to manufacture with and ask for. I may need 50 of these in the future. Thanks for your help on this.
RE: Gen Set Improvements
Use inline 6 cylinder engines.
Run at an rpm that has minimal vibration.
Change bore stroke, crank length to reduce vibration at required rpm.
Change compression/chamber shape to slow and stabilise combustion.
Change fuel injection pressure/nozzles/timing to slow and stabilise combustion.
Use a petrol engine.
Incorporate balance shafts.
Use more sophisticated engine mounts, like hydraulic dampened units.
Use a flexible coupler between the engine and generator.
Increase weight of flywheel, torsional vibration damper or block.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
An easier way to go, that doesn't need the engine maker's cooperation, is to fit better engine mounts, tuned to allow the engine to move around without transmitting much vibration to the substrate.
Mike Halloran
Pembroke Pines, FL, USA
Since you are running at a single speed you can optimise the powertrai mounts for that speed alone.
Note that a petrol engine of the same stroke etc will vibrate just as much at second order.
Is it a trade secret exactly which units these are? 50 engines is enough that the manufacturer will at least pay attention to your questions.
Cheers
Greg Locock
