Catia V4 to V5
Catia V4 to V5
Catia V4 to V5
When I bring a part from V4 to V5 from Enovia, some of the attached parts are rough and out of round. Can I clean those up somehow?.
RE: Catia V4 to V5
Do you know if the V4 geometry was the older Solid-M type (faceted), or the newer Solid-E type (exact)?  Sounds like you might be seeing the faceted solids. If you still have access to V4, you can convert Solid-M to Solid-E.
RE: Catia V4 to V5
Thank you Jackk. I don't have a V4 account. Only an Enovia, and V5 account. I'm sure that the engineers that control the models put them in as M and not E. The actual model opens normal, but I guess it's the dittos that look funky. Thank you for your help. Rod.
