Heat absorption of CO2 phase change
I work with computers and know very little of thermodynamics. I would like to know how much heat approximately that a certain volume of co2 will absorb when it changes phase from a liquid under pressure to a gas at 22 degrees C. I have searched google and your forums. If someone could give me an approximate or guide me to a place where I can learn about this I would appreciate it.
Kyle.
RE: Heat absorption of CO2 phase change
Liquid at what temperature to gas at what temperature and pressure?
If you are looking for the heat of vaporization at 22 C, it is 60 BTU/lb or 33 cal/gm
