Location of a sphere
I am curious your opinion about following issue:
Let's say I have a part like on attached picture, but I would not want to use spherical tolerance zone, because the location of the knob relative to datum C is not so important to me - it can be greater in this direction.
I am wondering how this requirement could be defined. Of course I have some ideas, but I would like to compare them with other opinions. Any hints?
RE: Location of a sphere
|Position|spherical diameter "BIG"|A|B|C|
|Position|spherical diameter "SMALL"|A|B|
My thinking was rather to somehow define cylidrical tolerance zone for a sphere's center location. Para. 5.15 of Y14.5M-1994 standard (or 7.4.6 of 2009 version) says that: "Where it is intended for the tolerance zone shape to be otherwise, a special indication is shown, similar to the example shown for a bidirectional tolerance zone of a cylindrical hole"
Frank
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
There has not been any evidence that would necessitate a spherical tolerance zone for the sphere. Might you show the assembled condition?
I personally believe that three bidirectional tolerance zones would be the answer to your situation.
I do not have any practical example to present - I was only imagining a situation when a functional requirement determines positional tolerance zone shape to be cylindrical not spherical.
What you are proposing is making tolerance zone shape cubicoidal, so this is not exactly what I wanted to achieve.
Generally, if you want the center of a sphere controlled ... you are going to use a spherical tolerance zone. If you're only worried about the boundaries of the surface ... that's a call for profile of a surface.
In the first case, you could use a gross spherical tolerance zone for the first FCF, then a cylindrical zone for the second separate FCF (i.e. two FCFs stacked up as opposed to a composite positional control because the second level of a composite control is a refinement of orientation, not location, as in '94). In the second case, two stacked profile controls could be used; the first to control the size & location of the surface wrt A/B/C, the second to refine the size/location wrt A/B only.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
I believe that is the direction that should be taken. If you consider that the datum features in this case are planar and the locus of points a given distance from the planes would result in a cubicoidal or rectangular zone, andthat is where we should be with the definiition. Perhaps if the shperical features were more that one, consideration could be given to another approach to accommodate the assembled relationship of multiples. However, there being a single sphere, not required.
The same would apply to a single hole or pin in a rectangular plate. Diametric pos tol not required. Only for the assurance of assembly when a pattern is used.
