Virtual wall stiffness value's
Hi Guys,
Simulate a flange support with a virtual wall.
Now, how does one calculate the stiffness of this wall?
E/t [N/m^3] is suppose to be the axial stiffness, where t is the wall thickness. Can one clarify this somewhat?
Can i also retrieve the stiffness with a test model? Suppose i would load a similar setup and measure the compression?
Would the stiffness then be: Stress / compression distance?
RE: Virtual wall stiffness value's
Greg Locock,
what do you mean with unit force?
Thanks you in advance.
Unit Force = 1 N or lbf in the direction of the load. The concept is right out of any structual design text.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
"Node news is good news."
I think the OP needs to share more about what he is trying to model and what result he is after.
TOP
CSWP, BSSE
