Do wind turbines using AC/DC/AC topology increase short-circuit power?
Dear all,
Do wind turbines using AC/DC/AC topology increase the grid short-circuit power?
Best regards,
Herivelto Bronzeado
Best regards,
Herivelto Bronzeado
RE: Do wind turbines using AC/DC/AC topology increase short-circuit power?
In this case, could I consider that a wind farm with 50 wind turbines running with this configuration (AC/DC/AC) would increase the short-circuit level by 50x1.2-1.5pu?
We had a problem in a substation busbar (69kV) and we suspect that the wind farm has contribute to the increase of the short-circuit level. But we could not prove that sofar. It is connected 80km away from our substation, being fed by a single line of 69kV.
Do youy think that the influence of that wind farm is considerable?
Herivelto
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
The wind farm is embeded in the distribution system and we, as a transmission company, have no contract with them.
My question is a general question as I think that the converter limits (or cut) the current during a short-circuit in the grid.
Best regards,
Herivelto Bronzeado
Alan
http://
See page 52 onwards.
Marmite
The last integration study I performed (about two days ago) we were supplied vendor data that showed inverter limits right at 1.2 pu fault current. As a worse case you could assume 1.5 to 2.0 pu fault current, but that really is a poor substitute for the proper information.
Could we conclude that a machine with power electronics coupling does not increase tha shor-circuit level regarding to break current?
In other words, should we be worried about changing our circuit breakers in a substation when a wind farm with electronics coulpling machines is connected to that substation?
H. Bronzeado
