Engineering Desing Standards
I am in the process of putting together a set of design standards for a water company that does both potable water and recycled water distribution. I would like to get a handle on the design standards for the potable water system (pipes, booster stations, wells, etc.). Do any of you have a template or a set of good design standards for potable water systems that you have that you can share with me. It will be very helpful, so I don't have to reinvent the wheel... Thanks in advance.
RE: Engineering Desing Standards
here is an example:
http://phoenix.gov/WATER/desstand.html
http://www
Cedar Bluff Engineering
http://cedarbluffengineering.webs.com
If so, it sounds like they may already have to abide by at least some of the design standards of the local municipality.
In my area, we have one private water utility that owns/operates a number of wells, pump stations, and distribution system. But, they have emergency tie-ins to the public water system - mostly becuase they have fire hydrants that the fire department must be able to tie into and reliable pull water from.
Because of those emergency tie-ins, they have to abide by the local public utility design standards - at least at the fire hydrants and at the tie-in points.
