Error ansys 12.0
Error ansys 12.0
I have two problems with Ansys WB12, when I try to Structural Analsys I import the file (from Pro/E in igs or t_x), bought me an error
"Unable to attach to geometry file" and subsequently
"Geometry interface not found"!!!
How can I fix??
Excuse me for not perfect English!!!!!!
How can I fix??
RE: Error ansys 12.0
www.priamengineering.co.uk
Thanks!!!!
i have done it so it is real solution. (also try to find this in ansys help file) this procedure is there too.
Pro/e send file to ansys mechanical, and benefit is that you geometry is translated without, or minimum errors.
Hope it helps
Thank you, I managed to solve problems!!!
