Excavating near a 4' garage foundation
Ok, here are the facts:
1) location - Bettendorf, IA
2) structure - 4 car garage composed of 2-30' sections at 45 degrees from eachother.
3) foundation - 4 feet
4) footing - trench footing 16" wide by 6" deep
5) the problem - The homeowner would like to construct a tiered patio along the outside of the garage foundation. A 15' potion or the patio, to either side of the 45 degree common point would need to be graded 2' below the current grade. This would lower the grade to within 2 feet of the footing. Needless to say there is concern with frost heave. We are looking for comments/solutions for the problem. The garage is insulated with r-19. Thank you for your suggestions.
RE: Excavating near a 4' garage foundation
