Troosite structure.
Troosite structure.
Dear all,
we are doing the gas carburising process in pit type furnace, (average case depth upto 2.8mm). we have observed some different type of microstructure (surface) at certain batch. this structure like a giraffe skin structure. and its coiming only at surface. but we have checked the hardness on structure(by micro hardness) it's around 57/58 HRC.
as per Our Quality team statement that structure is troosite, but i was not accept. And i dont have any proper document for prove the structure. But i explaind about the troosite structure. enventhrough they are not accepting.
pl guide me how i can explain about the troosite structure.
Remamber: i have to explain to the non-metallugist.
RE: Troosite structure.
What I consider "giraffe skin", with light boundries and darker interiors, would occur with a grain-boundry network of carbide (which etches light) with tempered martensite interior (which would etch darker). This is caused by too high a carbon content on the surface. With this condition, the hardness is generally unaffected. This is usually a very undesireable condition since it can crack very easily.
rp
thanks for your reply, and can you tell me, what is max hardness we can get from troosite structure.
Regarding giraffe skin =structure we have inspected the carbon content at surface after quenching is 0.65%C (by spectro machine). We have carbides network near the surface. but that also with in range.
pl guide me, if iam wrong,
May be this structure will come, if we have maintained the high carbon content at the time of activation in carburinsing cycle or diffusion time is not sufficient.
or the 850c holding time is very high at low Cp.
I cannot tell you the max hardness of a troositic structure, I would guess almost as hard as a fully martensitic structure with the same carbon content.
The 0.65% C on the surface seems a bit low for a carburized case, but without knowing the steel chemistry, it may be fine (it would be OK for AISI 9310 steel, but way too low for 1018, for example). Depending on the steel in question, this could lead to a mixed microstructure in the case, which could be called a troositic structure.
Whitout knowing exactly how your carburizing operation is set-up, I cannot guess on the problem. You are correct that a low carbon potential (Cp) with extended holding at 850C can lead to low carbon on the surface.
rp
