cheap solution on AC power regulator
Hello everyone,
The unregulated output AC power is from 22VAC to 30VAC, 2.5A max, but the input voltage range of the load is 22VAC~28VAC, load may demage when the power is over 28VAC.
Also, there is a motor inside the load and the motor is remote controlled, when it works, the un-regulated output voltage may drop to 28VAC, but it will go back to 30VAC when the motor stops.
Is there any way I can control the output voltage always safe---that means, when it's 30VAC, I can reduce it to 28VAC. When it's already 22VAC, don't do anything.
Mike
RE: cheap solution on AC power regulator
A crummy way would be to provide enough load to always keep the output below 28V perhaps a resistor.  (Horrible waste of energy.)
Or replace the transformer with one that has better regulation.
Or add an appropriate autotransformer to shave off the 2V without a lot of power loss.
Or buy the correct supply.
Keith Cress
autotransformer to shave off the 2V without a lot of power loss is good.
would you pls explain it in detail?
http://en.wikipedia.org/wiki/Autotransformer
Note that a normal transformer has to pass all the energy thru a magnetic structure. This makes a standard (fully isolated) transformer a certain size.  An auto transformer provides no isolation what-so-ever but this results in only a fraction of the power needing to pass thru a magnetic structure.  This allows them to be dramatically smaller than their counterparts.  Since you only need a 2V adjustment no isolation is probably needed.
Keith Cress
