Link Dimensions Between Several Parts?
I want to link dimensions between several parts. I have tried to use equations, but the problem with equations is that the dimensions used become locked. If I link a dimension, its only available for that specific part.
I need to be able to modify my assembles quickly without having to go in and edit each part by hand.
Thanks!
RE: Link Dimensions Between Several Parts?
Investigate Top Down or In-Context modelling.
Aother method is to reference a common external Design table.
I've taken to doing a lot with multi-body parts lately.  Functions how in-context parts in assemblies should.
Dan
www.eltronresearch.com
Dan's Blog
