What does a PE stamp get you?
My firm sold an industrial system with some heat exchangers, ladders, and platforms, along with the support structure that runs to the ground pads. We had an outside engineer, who is a PE review the designs. All drawings were provided to him in Autocad format. He made a number of required changes to support member sizes and locations and added additional supports. He also changed the way some of the connections were made, making some connections welded and upgrading the hardward grade used for bolting.
So we make all the changes and he approves the final drawings. Then some of our internal management gets involved and determines that we need a PE stamp for the state that the equipment will be installed in, which ends up costing us 50% more just to get the stamp. The PE seriously did nothing but take the same drawings and stamp them.
I should mention that the PE was already located in the same state as the installation job site.
So, did that stamp actually serve any real purpose? Why hadn't we done our due diligence by contracting and paying the PE for his services?
RE: What does a PE stamp get you?
Plus having a registered PE as the designer may be a statutory requirement for good reasons, discussed umpteen times on this website.
Meeting legal requirements does not necessarily assure quality, but minimized liability.
Rafiq Bulsara
http://www.srengineersct.com
Civil Development Group, LLC
Los Angeles Civil Engineering specializing in Hillside Grading
http://www.civildevelopmentgroup.com
http://www.civildevelopmentgroup.com/blog
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
www.PeirceEngineering.com
If he was identified originally on the original drawings, I would agree too, it is unethical to charge additional money. But not otherwise.
Rafiq Bulsara
First, yes it was the same engineer who did the engineering calcs that ultimately provided the PE stamp.
Second, my company was not listing him on any drawings, but there was official correspondence going back and forth between our company and the engineer where he was giving directions on the needed modifications and approvals for drawings.
His name and/or initials were not being provided on any drawings since he was just being used as a consultant to verify the design drawings.
Rafiq Bulsara
The engineer has all the rights to charge extra for additional request of any kind. especially, if the discussion earlier was (I presume) that sealing and signing would not be required. The Owner is also not completely blameless in thinking that they would get away without having a PE stamp to begin with. They sought for it only as a after thought.
Rafiq Bulsara
Look at it this way...in the first part he was helping you with YOUR design.....in the second part it became HIS design.
ZCP
www.phoenix-engineer.com
Just for everyone's information, the initial charge was $3000 and there was an additional $1500 for the stamp.
Also, so we're all clear, the company did all of the design drawings using in house engineering. The comments from the PE review were related to adding a piece of structure here and there, changing a connection from bolted to welded, upgrading hardware specs, and such. So he did not actually do any drawings, just review and comments on modifications for the company drawings.
It does sound like the consensus is that he might be liable anyway without the stamp, but the stamp makes it official.
There is a big difference between providing a few comments and sealing drawings, especially if this is in an industrial setting where licensure may not be required.
On the other hand, the PE probably should have known that a stamp would be required.
It sounds like an inexperienced project manager may have been involved and did not properly understand or communicate the total scope of work to the engineer.
If you don't like the fee, that is an entirely different issue. It certainly is not a rip off. Imagine, how much it would have cost you had he just declined and said, "I do not need $1500 but I would not sign it as it was not the agreement!" You also have the option of not hiring him again. He obviously does not see that as a threat. All seems even to me.
Rafiq Bulsara
I am not complaining about the total costs or even an additional fee. I think the costs are reasonable.
My original question was this:
We had already contracted and paid the PE for engineering services that he had provided back and forth in writing via email. Then someone in the company thought, hey, just to cover ourselves we should make sure those drawings are PE stamped. Please note the same PE ended up providing the stamp and he was already located in the same state as the jobsite.
So just to clarify again, my question was related to whether the company actually gained any additional liability protection by getting the drawings "stamped" versus not knowing that the same PE had already approved the drawings and the design in writing, but just hadn't provided a "stamp" because we hadn't requested one.
By stamping, he officially owns the entire design, even yours.
Once a matter goes to litigation, all ethical logic go out of the window and the outcome is only dependent on who has shrewder lawyer and not necessarily who is right or wrong.
Rafiq Bulsara
Your company almost certainly gained some liability protection from having a PE seal on the plans.
Without the seal, the plaintiff would sue only your company. You would then turn around and sue the PE for damages that you suffered, meaning extra lawyer time and possibly an additional trial.
Now that you have the PE seal on the plans, the plaintiff would likely sue your company, the PE's company, and the PE individually.
Assuming the PE's company has professional insurance, the most likely outcome in the case of a negative decision against you would be some monetary split between your company and the PE's company with no additional suits involved.
Seems cheap to me.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
I'll say that you guys have been great and I've learned a lot. Going forward, we'll pay the extra money for the "stamp" and I'll keep my wrong opinion to myself, since I didn't think it mattered and I was clearly wrong.
Thanks again to all of you.
Rafiq Bulsara
Cheers
Greg Locock
The seal basically formally signaled the work has been finalized & no further modifications or additions would follow.
To assume a PE should not be involved in giving advise at any stage other than the absolute final stage is rather inflexible.
