Nitrogen Purge Valve
Hello All,
I'm new to this forum and have a question to ask. I'm looking for a manufacture that makes miniature purge valves that are found in today's binoculars. It would be a 2-way flush mount design. Any feedback would be much appreciated.
Quick note: I did call a couple of binocular mfg's and found out they weren't very helpful.
Kind Regards,
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2009 SP 4.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
RE: Nitrogen Purge Valve
Not sure if this is the right place, but Lee in Connecticut makes all sorts of miniature valves.  Probably something you can use direct from their catalog.
Thank you very much! I use to use Lee Plugs at my old job years ago and forgot about them.
Best,
Mechanical Designer
