delete face command default setting,can I change it to delete & patch?
I frequently use the delete face command but mostly use the delete and patch option.  Is there a way to set the default option to delete and patch instead of delete and fill?
RE: delete face command default setting,can I change it to delete & patch?
What version and SP of SW are you using.
The command used to keep whatever you used last.  It was broken in SW2010.
SW is aware and I think it will be fixed at some point in the future.
There is a post somewhere over on the SW forums on the subject.
Cheers,
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2010 SP2.1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
sw2010 sp 2.1
SW2010 sp 2.1, HP Z400 Workstation
Intel xeon w3580@3.33GHz,Win7 pro 64bit
Quardro FX1800
