Process for creating a Wire Wound Toroid???
Anybody ever make a toroid assembly in Inventor? How'd you do it or how would you do it? It's easy enough to "wrap" a wire around it but how can I make it follow a single path and in increments like in the attached pic?
Thanks.
RE: Process for creating a Wire Wound Toroid???
I would probably use a 3D intersection between extruded surface and revolved surface as a Sweep path.  Then pattern as needed.
sorry, it appears that cadforum.cz needs registration, my browser logs me in automatically. Again, should be simple and no privacy breach required.
i've done this a few times. And the pictures WERE pretty! They also showed how tight the assembly was with the wound wire. Start with a straight wire the correct thickness tangent to the coil(at the bottom).Use a sweep and a 3d line to approximate one revolution then use a circular array to connect the segments. In this case, every third instance would require and adjoining wire.(and another array)
This kind of pictoral view is a nice addition to the fabrication procedural notes.
