Cranked or Funnel Dimension Leaders - View Alignment
Hey All
Probably a coffee-time challenge for most of you here...
We often have to use cranked or funnel type dimension leaders here and have two methods for NX4 - neither of which I feel is wholly satisfactory.
I've come up with a new method but to make it real sweet I need to ensure a detail view (Detail B in attachment)gets dragged along with its parent view (Section A-A in attachment) when its moved.
I've tried the options in Edit>View>Align View (eg Point to Point) but no joy so far....beginning to think I'm missing something easy here - any takers?...
Adeo
Senior Designer
Aero/Industrial Gas Turbines, Aerostructures, F1, Catia V5 & NX4
RE: Cranked or Funnel Dimension Leaders - View Alignment
However, getting back to your need for so-called 'cranked' dimensions, have you ever considered just changing the angle of the witness lines, as shown in the attached image?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Re: linking multiple views - shame
As far as the 'cranked' dimensions - For sure, I offered the simple, quick solution you describe but that style is flatly rejected by the checkers here!
For what its worth - anyone who needs to do this wholly within a drawing (ie if they do not have write access to the drawing's child .prt), please see attached as a possible solution....
Comments on how this method could be improved are welcome
Cheers, Gruss
Adeo
Senior Designer
John R. Baker, P.E.
Industry Sector
Cypress, CA
Your opening line could be read two ways where the words "like to see" could be read to mean you'd welcome the creation of such drafting standard, or to simply challenge somebody to find an existing one. I suspect you meant the latter, but I'd add that I wouldn't like to see the former. It seems to me to be a horribly complex and unnecessary addition to the software to want to make given that you can just crank the dimensions over sideways, create an extra view or a detail view to de-clutter your dimensions.
It isn't that I want to see software limited by standards written for manual drafting it is only to say that just because you can conceive of a different method doesn't always mean that it is a better idea. That may just be my view and I don't expect it to be regarded as any more than that, but if I had to choose between knowing my maintenance went towards developing three sided blends or drafting improvements then I'm going to opt for the modelling enhancement every time.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
You're right, I was asking for someone to produce a Drafting Standard where this particular dimension format was supported in.
John R. Baker, P.E.
Industry Sector
Cypress, CA
My company also for 'for drawing view clarity' usse cranked dimensions when one or both of the extension lines has a log in it.
I have submitted ER's for this in the past, but am still waiting.
John B, if you have ever seen the 'jog' (I think it was called) command in ProE, that's it.
Its not to support a specific drafting standard, its a clarity issue, particularly if a drawing is also going to me microfilmed.
It would be a useful addition to 'in my opinion' a good drafting toolset.
Cheers,
NXj
Have you checked out the 'ordinate' dimension feature?
This has a 'dogleg' function which is basically what you are trying to achieve.
It might not give you entirely the same result but it is robust!
For what its worth I'd quite like to see this feature too!
Jon
Haven't done much of creating user defined symbols, but I'll try it out - seems like a more efficient method tho...
@NXj/JohnR - thanks for your comments - it is indeed a CLARITY issue, and is something that is indeed also supported in other CAD packages (past AND present) for just that very reason.
Cheers/Gruss
Adeo
Adeo
Senior Designer
