Thread/Tap Command - No Minor Thread Available
Hi All,
I want to model a thread on a shaft. If I use the thread command, it will not let me specify the thread minor diameter.
There is a 'Thread diameter' field but Catia gives me an error if this is not the same as the shaft diameter that I have already modelled.
I don't want to create tables, I just want to use the command, as a one off. Pitch is available but that will not control depth without tooth angle.
Really grateful for any help here.
Ape
