Remember constraints
in NX3, on the mating conditions mask, it was easy to create 'Remember constraints'.
Now in NX7, the command ask me the component and constraints.
In a big assembly with lots of constraints....it's not so intuitive to select the associate component constraints..
Have you some suggestions ?
Thank you
Thank you
RE: Remember constraints
- resize it in the ant select the component activate the glases in the dependency window and select the contraints connected to the part
hih
have you tried your solution ?
Any time I click on the 'Remember constraints' command, all it's reset in the Ant and dependencies windows.
