Edit dimensions in Work Bench
Hi All,
I have a problem in editing dimensions in work bench. An error message is coming. I have attached it. "Over defined dimension cannot be modified."
Please help me.
RE: Edit dimensions in Work Bench
After dimensioning the diameter of the circle then adding dimension V3 (which looks to be the radius of the circle and not necessary) is over defining the dimensions, that is why you get the error message. These two dimensions do the same thing and that is defining the radius/diameter of the circle. You do not need both of them in order to define your circle.
You need to remove either the diameter or the radius dimension. You can keep only one them.
